Creating a Wire Port and Setting the Frequency
Add a wire port and voltage source to the Yagi-Uda antenna.
- Add a wire port to the middle of the yagi_active element.
- Add a voltage source to the port. (1 V, 0°, 50 Ω).
- Set the frequency to freq.
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Calculate the S-parameters (coupling) over a frequency range for three monopole antennas located near the front, middle and rear of a Rooivalk helicopter mock-up.
Calculate the coupling between a helix antenna and a Yagi-Uda antenna located in front of a large plate. Reduce computational resources by using the uniform theory of diffraction (UTD) and an ideal receiving antenna.
Calculate the near field, far field and spherical modes of a helix antenna. Export the fields to a file to use as an ideal receiving antenna.
Calculate the antenna coupling between a Yagi-Uda and helix antenna. Create the Yagi-Uda antenna and use an ideal receiving antenna in place of the helix antenna.
Create the variables and named points used in the construction of the Yagi-Uda antenna.
Build a parametric model of a Yagi-Uda antenna. Use variables and named points already created.
Create the plate. Apply the UTD solution method to the plate.
Define the calculation requests in CADFEKO.
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Run the Solver to compute the calculation requests.
View and post-process the results in POSTFEKO.
Calculate the coupling between two horn antennas separated by 60 wavelengths. A metallic plate between the horn antennas blocks the line-of-sight coupling. Replace the horn antennas with a far field equivalent source and ideal far field receiving antenna.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
