Adjust Plot View
Adjust the plot view to analyze the material property data.
Choose one of the following:
- Double-click the material.
- Hover over a material, click
A window opens to the right.By default, the Info tab displays general information of the selected material.Note: Click
to view the material information in a full
screen mode. - Click Plot.
Select the required material data under the Plots list.
The selected material data is displayed as a plot.
Drag a square using the cursor point to zoom the curve plots to read the data. Double-click the cursor point to reset the axes of a plot.
Hover over the plot, as you move the cursor, the X and Y values are displayed.Figure 1. Plot Details
As you move the cursor on the plot, the plot options menu is displayed. The following table explains the usage of plot options:
Icon Description
Click to zoom in the plot curves.
Click to zoom out the plot curves.
Click to auto scale the plot curve's view.
Click to reset the axes of a plot.
Click to export the plot data into a CSV file.
Click to export the plot data into a PDF file.
