View Material Properties
The material properties data such as Fatigue Properties, Mechanical Properties is displayed. The tested data for these properties is also displayed as supplied by the provider.
Choose one of the following:
- Double-click the material.
- Hover over a material, click
A window opens to the right.By default, the Info tab displays general information of the selected material.Note: Click
to view the material information in a full
screen mode. -
Click Properties.
The material properties data is displayed. In this example: The Fatigue Properties, Mechanical Properties for Axial Loading and also its testing data is displayed.
Figure 1. Properties Tab
Click Generic Data to view the generic data from the
same class of materials.
Figure 2. Generic Data
Click
to export the material properties data
along with the generic data.
- Click Plot to view the plot data for the selected material.
Select the plot curve value from the drop down list.
The chart data is displayed for the selected material and the curve value.
Figure 3. Chart Data
Hover over the plot area to view chart options such as zoom in, zoom out, auto scale to original chart view, reset axes, and export it as a PDF document.
