Set Preferences
Update your material database view preferences.
You can view the entire material database and skip the AMDC landing page by selecting the Skip Landing Page check box.
Click Preferences from the action ribbon.
Figure 1. Select Preferences -
Choose the language from the Select Language list
box.
Figure 2. Set the required Preferences -
Choose the unit system from the Select Unit System list
box.
Figure 3. Unit System Preferences -
Choose the required theme to set it for the application from the
Theme list box.
Figure 4. Theme Preferences - Select Use default sort. It displays materials in the database with the most complete data first.
- Select the Skip Landing Page check box to skip the landing page every time you log into the AMDC application.
Fill Data Gaps is an integrated tool that can fill gaps in the material
data when required. This will improve the usability of the material and making
it applicable to multiple simulations types.
- Select Generic data to predict the missing product data using the identical trade products data
- Select Artificial Intelligence to predict the missing curve data using artificial intelligence.
Click Apply.
The browser refreshes to display the set preferences.
