View Material Details
Visualize advanced and accurate material properties and curves. Also, view material impact using Global Warming Potential (GWP) and set your data preferences.
AMDC evaluates material database for each material's completeness and usability and then sorts data based on its available material property data, curve data, and models.
You can disable default sort from the Preferences menu.
