View Long Term Heat Aging Plots
Understand a material's thermal endurance and Arrhenius parameters by visualizing Long Term Heat Aging (LTHA) plots.
Select a material.
The Info tab displays general information about the selected material.
Click Plots.
The Plots list is displayed.
Select the LTHA Stress at Break plot from the list.
The selected plot is displayed.
Figure 1. LTHA Break at Stress Plot -
Click
on the plot options menu.
Tip: Hover over the plot area to view the plot options.The LTHA Stress at Break and Thermal Endurance plots are displayed.Figure 2. LTHA Stress at Break and Thermal Endurance Plots -
To analyze the material data, enter a threshold value in Define
threshold in %.
The Thermal Endurance points are displayed. If a minimum of three thermal endurance points are intersected then a regression line is drawn automatically and it calculates the Arrhenius Parameter for a material.
Figure 3. Define Threshold in % Click
to export the chart as a PDF document.
Select the Percentaged Representation check box.
The thermal endurance result is calculated in percentage with the 100% stress applied to the material at different temparatures.
Figure 4. Thermal Endurance Result in Percentage
