Download Squeak and Rattle Material Data
Download simulation-ready best and worst-case scenario material pairs data from SMDC Stick-Slip database to Squeak and Rattle Director (SnRD).
Learn how to download simulation-ready best and worst-case scenario material pairs from the Stick-Slip database to the Squeak and Rattle Director (SnRD) for use in squeak and rattle simulations. The best-case scenario is defined as the material pair with the lower impulse rate value while the worst-case scenario is the pair with the higher impulse rate value.
  • To download simulation-ready material pairs, select the first material pair from the Stick-Slip database as the worst-case scenario in SMDC. SMDC will then automatically suggest the opposite, best-case scenario material pair.
  • The suggested pair will always use the same material types as the first material pair. For example, if you select ABS & PP, the suggested pair will also be ABS & PP.
  • Based on your requirement, download two pairs of material data or single pair of material data.
