LoRa Server Stack
Installation
The LoRa Server Stack can be deployed by adding the "App - ECP LoRa Server Stack" to your Space from the Marketplace.
- gateway bridge
- network server
- application server
- postgresql
- redis
- mosquitto
The stack is initialized so that all the pieces can talk to each other. The gateway bridge itself is available on port 1700 (UDP) of the ecp-lora-server-stack-gateway-bridge service (internal to the cluster) and can be exposed as a node port if necessary (for use with external LoRa gateways).
The network band defaults to "EU868" and can be set using the override parameter in the deployment (see Create a Deployment).
Note that you might want to consult the LoRaWAN Regional Parameters specification for valid values that apply to your region. See: https://www.lora-alliance.org/lorawan-for-developers.
- AS923
- AU915
- CN470
- CN779
- EU433
- EU868
- IN865
- KR920
- RU864
- US915
