Add an Edge App to Your Space
- To add an available Edge application from Marketplace to your space, click and see the list of available apps you can choose from.
Click on the desired application to open the side pane. Click Add to
Space. The app ECP Virtual Meter is used in this example.
Figure 1. -
Click Add to confirm the action.
Figure 2. The selected application is moved from the Marketplace to Edge Applications.The Edge Application version is not editable. However, when a new version of an Edge app is available, you can update the Asset with the latest version and make deployments to it.Figure 3. -
To deploy another version to the Asset, select
Configuration.
This will lock the selected version of Edge applications.
- Enter the Name and any required parameters and click Save.
