View Job Summary
View the job summary, job CPU cores, memory, view job result files using the text, plot and image viewer and perform job management tasks.
Click the Jobs tab located in the upper left-hand of
the page.
The job monitoring page is displayed with the list of jobs that are submitted.
Figure 1. Job Monitoring View
Perform one of the following options:
- Click the job name from the list.
- Right click the job and click the View Details from the context menu.
Select the job name and click
in the toolbar list.
The job Summary tab is displayed:Figure 2. Job Summary Tab
The job summary tab provides the following information:- Job Metadata - provides information about application name, job name, job status, CPU efficiency, and Memory utilization.
- Job Results - from the files list you can select a file to view its content in the Text, Plot or Image viewers. You can monitor the progress of the job by viewing the updated contents of the selected file. You can visualize plots and animations from result files for both running and completed jobs.
Perform job management tasks like View Details, Connect to Desktop, Download, Resubmit, Terminate, and Delete. The tasks buttons appear based on the Job Status.
If the selected file of the job is in running state, then the file will be displayed with the tailing options like Play, Pause, and Stop.Figure 3. Job Summary File in Tailing Mode
Note: The Walltime argument will be displayed if it is set as an input field in the application definition.Figure 4. Walltime Argument
