Standard inputs
  1. Line current, rms
    The line current supplied to the machine: “Line current, rms” (Line current, rms value) must be provided.
  2. Field current
    The current supplied to the field winding of the machine: “Field current” must be provided.
  3. Control angle
    Considering the vector diagram shown below, the “Control angle” is the angle between the electromotive force E and the electrical current (J) (Ψ = (E, J)).
It is an electrical angle. The default value is 45 degrees. It must be set in a range of -90 to 90 degrees.
This range of values covers all the possible working point in motor convention.
Definition of the control angle Ψ - Motor convention
Advanced inputs
The list of advanced inputs dedicated to this export are listed below.
For more details, please refer to the section 4.7.5 - List of generic advanced inputs.
  1. Rotor initial position mode
    By default, the “Rotor initial position mode” is set to “Auto”.
  2. Rotor initial position
  3. Mesh order
    The default level is second order mesh.
  4. Airgap mesh coefficient
