Customize Table Columns
Add or remove material properties to be displayed as columns in the table view.
Click
on the right pane.
Figure 1. Customize Table -
Select Customize Table from the menu.
The Customize Table window is displayed.
Figure 2. Customize Columns - Select the required material properties to be displayed as columns in the table view.
- Enter the material property name in the search field.
Click Apply.
The selected material porperties are displayed in the table view.
Figure 3. Customized Table Columns
