Premium Access to AMDC allows you to leverage advanced search using multiple search criteria, compare materials, and
view curve data. You can also download CAE material data in the required units to your workstation.
Launch the application to access the Altair material data. You can customize and launch the application from Favorite
Apps, on the Altair One Home page.
View information such as material name, quality, type, provider, version, chemical composition of a material, material
test information, and detailed material properties.
The material properties data such as Fatigue Properties, Mechanical Properties is displayed. The tested data for these
properties is also displayed as supplied by the provider.
Many materials have multi point data associated with them (For example, stress-strain data or PVT data for molding
applications). Such data can be viewed as a plots in AMDC.
Visualize the correlation and interdependency between two properties data. The independent property data is plotted
on X-axis while the dependent property data is plotted in Y-axis.
Advanced Search allows you to build a search query by combining multiple search criteria. Use filters to find properties
and define value ranges. You can also add filters such as availability of plots, certifications or regional availability
to quickly find relevant materials.
data or PVT data for molding applications). Such data can be viewed as a plots in
AMDC.
You can view plots from the Properties tab. If you wish to
view all the plots of a material then view the Plots
tab.
Choose one of the following:
Double-click the material.
Hover over a material, click
A window opens to the right.
By default, the Info tab displays the general
information of the selected material.
Note: Click
to view the material information in a full
screen mode.
Click Plots.
A list of available curves for the selected material is displayed. Figure 1. Plots List
Select the required curve from the list.
The material properties data for the selected curve is displayed as a
plot. Figure 2. The Material Data as a Plot
Adjust Plot View
Adjust the plot view to analyze the material property data.
View Scatter Plot
Visualize the correlation and interdependency between two properties data. The independent property data is plotted on X-axis while the dependent property data is plotted in Y-axis.
