Premium Access to AMDC allows you to leverage advanced search using multiple search criteria, compare materials, and
view curve data. You can also download CAE material data in the required units to your workstation.
Launch the application to access the Altair material data. You can customize and launch the application from Favorite
Apps, on the Altair One Home page.
View information such as material name, quality, type, provider, version, chemical composition of a material, material
test information, and detailed material properties.
The material properties data such as Fatigue Properties, Mechanical Properties is displayed. The tested data for these
properties is also displayed as supplied by the provider.
Many materials have multi point data associated with them (For example, stress-strain data or PVT data for molding
applications). Such data can be viewed as a plots in AMDC.
Advanced Search allows you to build a search query by combining multiple search criteria. Use filters to find properties
and define value ranges. You can also add filters such as availability of plots, certifications or regional availability
to quickly find relevant materials.
Select one or more materials to compare the chosen materials data.
You can select up to ten materials to compare the material data and its plot data.
Compare Material Data
Compare materials using the properties data provided by the provider.
Compare Plots
Compare materials data using the plot curve values. You can also overlay selected materials and check the curve values in a single plot axes.
