Premium Access to AMDC allows you to leverage advanced search using multiple search criteria, compare materials, and
view curve data. You can also download CAE material data in the required units to your workstation.
Launch the application to access the Altair material data. You can customize and launch the application from Favorite
Apps, on the Altair One Home page.
View information such as material name, quality, type, provider, version, chemical composition of a material, material
test information, and detailed material properties.
The material properties data such as Fatigue Properties, Mechanical Properties is displayed. The tested data for these
properties is also displayed as supplied by the provider.
Many materials have multi point data associated with them (For example, stress-strain data or PVT data for molding
applications). Such data can be viewed as a plots in AMDC.
Advanced Search allows you to build a search query by combining multiple search criteria. Use filters to find properties
and define value ranges. You can also add filters such as availability of plots, certifications or regional availability
to quickly find relevant materials.
Compare materials using the properties data provided by the provider.
You may filter the data further to view only the differences in the selected
materials.
Select the check box of the required materials to compare.
The Compare button is enabled.Figure 1. Select Materials to Compare
Click Compare.
The selected materials data is displayed in a table format. The compared
material data between general information and properties data is displayed for
the selected materials. Figure 2. Compare Material Data
Select Show difference only.
Only the difference in data among the selected materials is
displayed. Figure 3. Show Differences Only
For more information, see the following video demonstration:
