Premium Access to AMDC allows you to leverage advanced search using multiple search criteria, compare materials, and
view curve data. You can also download CAE material data in the required units to your workstation.
Launch the application to access the Altair material data. You can customize and launch the application from Favorite
Apps, on the Altair One Home page.
Advanced Search allows you to build a search query by combining multiple search criteria. Use filters to find properties
and define value ranges. You can also add filters such as availability of plots, certifications or regional availability
to quickly find relevant materials.
launch the application from Favorite Apps, on the Altair One Home
page.
Login to Altair One.
The Marketplace > All Apps page is displayed.
Click to launch the application.
Figure 1. AMDC App Card
Tip: Click to add AMDC to the Favorite Apps list in
the Altair One Homepage.
The AMDC landing page is displayed.
Figure 2. Landing Page
The landing consist of:
Quick Search for a
specific set of materials using a string value.
CAE view solver based materials that can be
exported to at least one CAE Application.
Material Selection view the entire Altair
material database.
Quicklink to preferred Software view
materials of a specific CAE Application material database.
Quicklink to preferred Material Type view the
specific material type database.
