Premium Access to AMDC allows you to leverage advanced search using multiple search criteria, compare materials, and
view curve data. You can also download CAE material data in the required units to your workstation.
Launch the application to access the Altair material data. You can customize and launch the application from Favorite
Apps, on the Altair One Home page.
View information such as material name, quality, type, provider, version, chemical composition of a material, material
test information, and detailed material properties.
The material properties data such as Fatigue Properties, Mechanical Properties is displayed. The tested data for these
properties is also displayed as supplied by the provider.
Many materials have multi point data associated with them (For example, stress-strain data or PVT data for molding
applications). Such data can be viewed as a plots in AMDC.
Advanced Search allows you to build a search query by combining multiple search criteria. Use filters to find properties
and define value ranges. You can also add filters such as availability of plots, certifications or regional availability
to quickly find relevant materials.
displayed. The tested data for these properties is also displayed as supplied by the
provider.
AMDC displays generic data
for some of the materials using the material's family data.
Choose one of the following:
Double-click the material.
Hover over a material, click
A window opens to the right.
By default, the Info tab displays the general
information of the selected material.
Note: Click
to view the material information in a full
screen mode.
Click Properties.
The material properties data is displayed. In this example: The Fatigue
Properties, Mechanical Properties for Axial Loading and also its testing data is
displayed.
Figure 1. Properties Tab
Click Generic Data to view the generic data provided by
the material's family group.
Figure 2. Generic Data
Click to export the material properties data
along with the generic data.
Click Chart to view the chart data for the selected
material.
Select the plot curve value from the drop down list.
Figure 3. Select Plot Curve Value
The chart data is displayed for the selected material and the curve
value.
Figure 4. Chart Data
Hover over the plot area to view chart options such as zoom in, zoom out,
auto scale to original chart view, reset axes, and export it as a PDF
document.
