Custom Templates
The WallMan indoor Lego feature offers the possibility to
define custom templates. As this procedure is different from the creation of predefined
template objects, the handling was adapted. Consequently, there is no toolbar symbol for
custom template creation. The custom template creation process works as follows:
- At least one wall in the current database must be marked using a corresponding tool.
- Press the right mouse button.
- From the appearing wall, context menu selects Copy to custom template or Cut to custom template depending on the desired function.
- Process the created template.
Custom templates are treated the same way as all other templates, so they can be processed,
inserted and recombined.
Note: Custom templates possibly show a deformation when a scaling and
/ or rotation operation is applied because of the lacking definition of the template’s
principal axes.
