Channel Impulse Response
The channel impulse response of the radio channel can be analyzed for each computed pixel within the simulation area.
Click icon. You have the possibility to specify an
evaluation location by positioning the mouse cursor in the result window. During mouse
movement, the graph window is updated automatically. After clicking, the channel impulse
response for the current location will be fixed.
Note: Channel impulse responses can only be analyzed if the simulation was calculated with
a ray-optical propagation model and the additional ray data output was enabled. While
loading the result file, you will be asked to load additionally available data. This
question has to be answered with yes to do analysis of the radio
channel.
![](../../../../../images/winprop/user_guide/proman/results/channel_impulse_response.jpeg)
