Matching Die
Create a matching die by offset.
- On the ribbon, click the Die Design tab.
Click the Die icon.
Click the Matching Die icon.
Select the die you would like to offset.
To reselect a die, in the guide bar, select Clear Selection
, and then select a different die. -
Select an offset method:
- CT Offset (default): Select the Construction Tree Offset method to create a child object in construction history.
- PS Offset: Select the Parasolid Offset method for a faster, one-click option, which creates a separate offset object.
- Adjust the Offset multiplier.
Adjust the Radius multiplier to set a different offset
multiplier for the fillet radius.
Note: If you want the Radius multiplier to be the same as the Offset multiplier, keep the default value of 1. If the offset is outside the original die, enter a value greater than 1. If the offset is inside the original die, enter a value less than 1.
