2025.1
Create a draw die in Inspire Studio that you can export to Inspire Form to perform a stamping simulation.
Create the draw die.
Trim the binder and add a round to finalize the draw die. Create a matching die by offset.
Discover new features and enhancements.
New to Inspire Studio? Learn the basics here.
Start using Inspire Studio with our interactive tutorials.
Create and edit a 2D sketch curve. A sketch curve is any "wire" entity such as a line, rectangle, circle, or arc.
Create and edit 3D curves by extending, rebuilding, intersecting, splitting, and projecting the shapes.
Create and edit 3D surfaces and solids by creating primitives or editing existing curves and surfaces.
Create polygonal surfaces that can easily be converted into NURBS surfaces.
Create new objects by manipulating and modifying source objects.
Quickly modify objects that are not a part of Construction History.
Deform one or more objects with respect to an axis.
Analyze curves and surfaces, import simulation data, or access the Design Table and Variable Manager.
Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined dimensions.
Create detailed 2D drawings of the selected parts of a complex 3D model from multiple perspectives.
Adjust the materials, environment, and properties of objects in the scene to create a photorealistic image.
In Inspire Studio you can animate an object or group and the camera. There are two methods of animation: key frame animation and path animation.
Adjust the user profile and configure the camera view.
Prepare the part to create the draw die.
Define one or more binders for the draw die. You can either assign an existing surface as a binder or create a flat from a new surface.
Create one or more surfaces that extend from the part to the binder, to aid in stretching and forming.
Create one or more surfaces that extend from the part to the binder, to aid in stretching and forming. These tools allow for more control over surfaces.
Define a bead line and create a drawbead from it.
Create the flange die.
Modify the die shape to compensate for potential springback after the part is formed.
Select an export method for your simulation data.
You can use C++ and Python to add custom operations and file formats.
Learn keyboard shortcuts and mouse controls for common operations.
Inspire Studio supports 3Dconnexion's SpaceMouse.
