Shell
Remove material and create thin walls to generate a shelled part.
                On the Geometry ribbon, select the
                        Shell tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
 at the lower right corner of the
                                currently displayed tool. - Click and hold the currently displayed tool.
 - Select
 - Select one or more faces to remove.
                In the microdialog, enter the desired thickness for the new shell.
                Note: Click the Reverse Direction
 icon to reverse the direction of the
                        shell. -
                Click Apply
                    on the guide bar or microdialog to generate the shelled part.
Create or Assign Variables to Parametrize a Model
Create or assign variables to parametrize a model. Variables can be created from a tool or the tool’s microdialog where f(x) is present.
You can create or assign existing variables via the microdialog or in various tools and contexts.
