Intersect Curves
Split intersecting curves or wire bodies into several curves.
                On the Geometry ribbon, select the Intersect tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
 at the lower right corner of the
                                currently displayed tool. - Click and hold the currently displayed tool.
 - Select
                To combine all targets and newly created curves, in the
                    guide bar select Options
, then turn on Combine
                    Curves.
             - Select the target curves, then select Tools on the guide bar.
                Select the tool curves, then select Apply
                Select the curves to remove, then select
                        Apply
