2026
New to Inspire PolyFoam? Learn the basics here.
Discover new features and enhancements.
Inspire PolyFoam is an essential toolset to simulate and validate the part design and physical processes that are required to create a polyurethane foam part.
Five basic steps are required to define and run a foaming analysis.
Learn the basics of the Inspire PolyFoam user interface.
Use the Systems tool to create and apply user-defined coordinate systems to loads, supports, and displacements.
Create and assign variables to parametrize a model. This allows you to quickly iterate and compare design concepts by tweaking the values of the variables.
View a list of glossary terms and definitions.
Learn keyboard shortcuts and mouse controls for common operations.
Start using Inspire PolyFoam with our interactive tutorials.
Create 2D sketches, surfaces, and solids with construction history and variables.
Set up your foam part, nozzles, materials, tooling and process parameters prior to analysis.
Set up your part, nozzles, materials, tooling and process parameters prior to analysis.
Run an analysis to minimize defects and prevent manufacturing problems for a foam part design.
Run an analysis to minimize defects and prevent manufacturing problems for a fluid part design.
Got questions? We have answers!
