Multi-Availability Zone Management on AWS
Configure the cloud environment so that cloud nodes can be deployed in several Availability Zones.
- An AWS virtual private cloud (VPC) must be created.
 - A subnet for each Availability Zone must be created and each subnet must belong to the same VPC.
NavOps attempts to deploy cloud nodes in the first subnet in the list. If there is no availability in that subnet, then it will attempt to deploy cloud nodes in the next subnet in the list and will continue until a subnet is found where the cloud nodes can be deployed or until all subnets are exhausted (i.e. scaling fails). NavOps attempts to deploy all requested cloud nodes in a single subnet. Cloud nodes are not deployed across subnets. This same process is followed each scaling cycle until there is availability for the cloud nodes.
10 cloud nodes are requested for scaling.
- NavOps attempts to deploy all 10 nodes in subnet-014c5607b.
 - If there is no availability in subnet-014c5607b, NavOps attempts to deploy all 10 cloud nodes in subnet-0622f6467.
 - If there is no availability in subnet-0622f6467, NavOps attempts to deploy all 10 cloud nodes in subnet-05c352abff.
 - If there is no availability in subnet-05c352abff, then cloud scaling fails.
