Add an existing AWS user account to NavOps so that you can
        create a cloud environment.
        You must have already created an AWS user account, given it administrative
            permissions and downloaded a CSV file containing an access key ID and a secret access
            key. The information in the CSV file is necessary to create a cloud account in NavOps. If you do not have this information see Create an Amazon Web Service User Account.
                Login to NavOps.
                Go to Clouds, and then select
                        Credentials.
                Click Add Cloud Credentials
                Select Amazon Web Services.
                Enter the following to add a cloud account:
                        For Name, enter any name for the cloud
                            account.
The name can be anything meaningful to your organization, e.g.,
                            aws_cloudaccount.
                        For Auth Method, select API
                                Key.
                            Note: You can also select the IAM
                                    Role if that is suitable for the cloud credentials.
                                NavOps must be installed on an instance hosted in AWS and have the
                                role associated to that instance.
                        For Access Key ID, copy and paste the value of
                                Access key ID from the downloaded CSV
                            file.
                        For Secret Access Key, copy and paste the
                                Secret access key value from the downloaded CSV
                            file.
                        For Partition, choose
                                Default. for public cloud
You can choose China or US
                                Gov to create credentials in those clouds
                (Optional) For Tags, enter the suitable tags for the
                    credentials.
                Click Test to check the credentials. If an error message
                    is displayed, inspect the details from the Tasks
                    list.
                Click Save.
