2026
Create 2D sketches, surfaces, and solids with construction history and variables.
Discover new features and enhancements.
New to Inspire Mold? Learn the basics here.
Start using Inspire Mold with our interactive tutorials.
View and edit the construction history of your model.
Global references are the global origin, axes, and planes shown in the modeling window. They can be helpful when creating and defining your model.
Learn about sketching basics including the sketch plane, legend, constraints, context menu options, and construction geometry.
Start a new sketch (S) and select a sketch plane.
Project selected geometry onto the sketch plane as construction geometry.
Extract curves resulting from the intersection of the sketch plane with selected parts or surfaces.
Sketch and edit a point, line, polyline (L), or line-arc.
Sketch and edit a rectangle (R).
Sketch and edit a parallelogram or a regular polygon.
Sketch and edit a circle (C).
Sketch and edit an ellipse or an elliptical arc.
Sketch and edit slots.
Sketch and edit an arc (A).
Sketch and edit a spline (S).
Use the Dimension tool (D) to define and/or constrain the dimensions of a sketch.
Create an image plane that you can use as a background reference image, so you can trace lines and curves to start your design.
Translate or rotate sketch entities.
Trim (B) or split a sketch curve.
Extend or shorten an entity of a sketch curve.
Round the corners of 2D sketch curves to create fillets (F) with the same radius or different radii.
Offset (O) or mirror (M) a sketch curve.
Create a linear or circular pattern of sketch entities.
Export the current sketch as a .dxf or .dwg file.
Break sketch constraints or relationships to other features.
Create and modify parametric surfaces and solids.
Use Quick Mode or Advanced Mode, depending on your needs, to define the parts, materials, runner system, and tooling for the molding simulation.
Run an injection molding analysis to minimize defects and prevent manufacturing problems.
Download the Mold Material Reference Manual to learn how to create new materials in Inspire Mold.
Got questions? We have answers!
