Export DXF/DWG
Export the current sketch as a .dxf or .dwg file.
  1. Double-click a sketch entity to enter sketch edit mode.
    Tip: You can also right-click a sketch and choose Edit or double-click a sketch in the Model Browser or History Browser to enter sketch edit mode.
  2. On the Sketching ribbon, select the Export DXF/DWG icon.
  3. In the dialog box, select a folder, name your file, choose between .dxf or .dwg, and then click Save.
