Extract
Extract selected geometry features and transfer them to a new part.
                On the Geometry ribbon, select the
                        Extract tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
 at the lower right corner of the
                                currently displayed tool. - Click and hold the currently displayed tool.
 - Select
                Select a sketch, face, edge, or point.
                Note: Your first selection sets the selection filter. For example, if you select an edge, then your remaining selections must be edges.
 - Select additional features to extract, based on your first selection.
                 Optional: Click the
 icon in the microdialog to break the reference
                    between the original part and the extracted part.
                Note: If you wish to restore the reference, you must click the
 icon before clicking
                            Apply.  -
                Click Apply
                    on the guide bar or microdialog to extract the selected features and create a
                    new part.
Tip:
        - Entities selected from the same original part will become a single new part, even if they are not contiguous.
 - Entities selected from different original parts will become separate new parts, even if the original entities were in contact with each other.
