Advanced Screen Capture
Record a video or take a snapshot of a specific area or the full screen with the current background.
- Select .
Configure the settings:
- In the microdialog, click Settings and configure the screen capture settings, which apply to both snapshots and videos.
Define the capture area:
- To capture a specific area of the screen, click Select Screen Area , and then drag to draw a box.
- To capture the full screen, click Select Full Screen .
Capture the screen:
- To take a snapshot, click Take Snapshot .
- To record a video, click Start/Stop Recording , manipulate the model as desired, and then click Stop Recording .
Depending on what option was selected in the Screen Capture Settings, either the Save As window will appear or the captured image/recording will be saved to the default file location.
The snapshot is saved as a .png file. Depending on the File format defined in the Video Settings, the video is saved as a .mp4 or .gif file.
Configure the screen capture settings.
- Include mouse cursor
- Select this option to include the mouse cursor when recording a video or taking a snapshot of the screen.
- Copy image to clipboard
- If selected, the image is copied to the clipboard and is available to the other applications.
- Show file save dialog
- If selected, the save file dialog is shown when saving an image or recording. The last selected location is remembered throughout the session.
- Save to a default file location
- Select this option to automatically save the video or snapshot to a default
location. The default location is
Documents/Altair/captures
To change the default location, click Select save location , and then select a folder.
- Capture delay (sec)
- Define the number of seconds that elapse before the video starts recording
or the snapshot is taken.
The default delay time is 3 seconds.
- Frame rate
- Define the number of frames displayed per second in the video.
The default frame rate is 24.
- File format
- Save the video as a .mp4 or .gif file.
