Default Streamlines Generated from Inlet Not Visible in Certain Regions
Condition
If you have a coarse voxel resolution, it can cause streamlines to be less detectable. Default streamline density is dependent on voxel mesh resolution.
Remedy
You can create local streamlines if the simulation has produced an inadequate amount.
- Run a fluids analysis.
In the results panel, select the Static
Streamline icon
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.The local streamline creation microdialog options appear.
. - Refer to Style Options to learn how to add and edit local streamlines, and for additional Static Streamlines post-processing options.
