Domain
Define the solid and fluid domains for the Fluids simulation.
Note: If you only need to analyze the fluid part without considering the surrounding geometry, then you can skip defining the solid domain, and go directly to defining the fluid domain. The solver will treat everything that doesn't have a boundary condition as in contact with a solid part.
