Porous Media
Turn an undefined part into a porous medium and define its characteristics for simulation purposes.
On the Fluids ribbon, select the Porous Media
tool.
- Select one or more undefined parts as porous media.
In the microdialog, define the characteristics of the porous medium.
Option Description Porosity Direction Choose between isotropic or unidirectional permeability. Flow Direction Click the
button, then select a face on
the porous medium to indicate the fluid flow direction.Note: This control is active only when unidirectional porosity is selected.Move Click the
button, then use the move tool
to change the angle of the fluid flow through the porous
medium. Note: This control is active only when unidirectional porosity is selected.Specific Heat Enter the specific heat of the porous medium. Conductivity Enter the conductivity of the porous medium. Porosity Enter the porosity of the porous medium. Viscous Resistance Enter the viscous resistance coefficient for the porous medium. Inertial Resistance Enter the inertial resistance coefficient for the porous medium. - Optional:
If you don't already know the viscous resistance and the inertial resistance of
your porous medium, you can calculate them with a Python script.
For more information on Python scripts and Inspire, see Inspire Python API.
