Condition
If you receive an error message that says GPU Out of Memory, follow the
instructions below:
Remedy
Check the Log file for a GPU Out of Memory message.
Run a fluids analysis.
In the Run Status window, right-click the completed analysis,
then select Open Run Folder.
Open projectParameters.cfdx.1.Log.
Evaluate the log file for GPU-related errors.
Increase your voxel size.
Prepare your model for a fluids analysis.
Click the Custom Fluids Run satellite
icon in the Analyze tool group.
The Run Fluids Analysis window appears.
Enter
a lower value for Number of
voxels.
Rerun the analysis.
