Specify Number of Voxels and Using Refinement Zones
- Prepare your model for a fluids analysis.
Click the Custom Fluids Run satellite icon in the
Analyze tool group.
The Run Fluids Analysis window appears.
- Enter a value for Number of voxels. The value you enter should specify a voxel size that results in at least 6 to 8 voxels across an inlet, outlet, or a narrow fluid path. Use at least 4 voxels across thin solids.
- Use the Zone Refinement, Part Refinement, or Wall Refinement tools to achieve the desired resolution. See Set Up and Run a Fluids Simulationfor details on these controls.
- Re-run the simulation.
