Prevent Recirculation or Backflow near Outlets
- Click the Geometry tab on the main ribbon.
                In the modeling window, double-click the outlet you would like to
                    extrude.
                Note: You can also use the Extrude tool on the Geometry ribbon for more complex extrude options. Refer to Extrude for instructions.
 - Use the white arrows to adjust.
