Monitor Simulation Convergence
To evaluate simulation convergence, you can track the history of global engineering quantities such as pressure, velocity, and temperature on the domain boundaries (inlets, outlets, and walls).
When these quantities stabilize and reach a constant value or show a periodically varying pattern, you can rely on the simulation results.
