/GRSPRI/BOX or /GRSPRI/BOX2
Block Format Keyword Describes the spring groups which are inside the box.
Only one box_ID is allowed:
| /GRSPRI/BOX/grspring_ID/unit_ID or /GRSPRI/BOX2/grspring_ID/unit_ID | |||||||||
| grspring_title | |||||||||
| box_ID | |||||||||
Definition
| grspring_ID | Spring group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grspring_title | Spring group
| box_ID | Box identifier, which is
defined in Boxes (Integer, maximum 10 digits) |
- Shell groups cannot contain 3 node shell elements (use /GRSH3N instead).
- If type is
BOX, all elements having all nodes inside the box or on its
surface are selected.
If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
