/GRQUAD/GENE
Block Format Keyword Generate a group of quad elements by listing the first and last element IDs in the range.
For each list, enter first node and last node (any number of lists may be input, up to 5 per Line). All nodes between first_ID and last_ID are selected.
/GRQUAD/GENE/grquad_ID/unit_ID | |||||||||
grquad_title | |||||||||
first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
Definition
grquad_ID | Quad group
unit_ID | Unit identifier (Integer, maximum 10 digits) |
grquad_title | Quad group
first_ID1, last_ID1,...first_IDn, last_IDn | List of first and last
quad identifiers (Integer) |
