/GRQUAD/MAT
Block Format Keyword Describes the quad material groups which belong to given materials.
Enter selected items numbers (any number may be input, 10 per Line)
| /GRQUAD/MAT/grquad_ID/unit_ID | |||||||||
| grquad_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| grquad_ID | Quad group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grquad_title | Quad group
| item_ID1, item_ID2,..., item_IDn | List of material
identifiers (Integer) |
- 1If item_ID is a negative number, the item number is deleted from the group.
