/GRNOD/NODENS
Block Format Keyword Describes the unsortable node groups by list of nodes.
Enter node numbers in the desired order (any number may be input, 10 per Line)
| /GRNOD/NODENS/grnd_ID/unit_ID | |||||||||
| grnd_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| grnd_ID | Node group
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| grnd_title | Node group
title. (Character, maximum 100 characters) |
| item_ID1, item_ID2..., item_ID10 | List of node
identifiers. (Integer) |
- Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
- Nodes are not sorted by Radioss, they retain the order entered. This option is only needed in interface TYPE8 and /XELEM.
