/GRBRIC/MAT
Block Format Keyword Describes the brick material groups which belong to given materials.
/GRBRIC/MAT/grbric_ID/unit_ID | |||||||||
grbric_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
grbric_ID | Brick group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grbric_title | Brick group
item_ID1, item_ID2,...,item_IDn | List of material
identifiers (Integer) |
- If item_ID is a negative number, the item number is deleted from the group.
- Brick groups may include tetrahedron and hexahedron.
