/GRBRIC/BOX or /GRBRIC/BOX2
Block Format Keyword Describes the brick box groups which are inside the box.
Only one box_ID is allowed:
| /GRBRIC/BOX/grbric_ID/unit_ID or /GRBRIC/BOX2/grbric_ID/unit_ID | |||||||||
| grbric_title | |||||||||
| box_ID | |||||||||
Definition
| grbric_ID | Brick group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grbric_title | Brick group
| box_ID | Box identifier, which
is defined in Boxes (Integer, maximum 10 digits) |
- Brick groups may include tetrahedron and hexahedron.
- If type is
BOX, all elements having all nodes inside the box or on its
surface are selected.
If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
