/DFS/DETPOINT/NODE
Block Format Keyword Locates the detonation point and set lighting time for an explosive material law.
/DFS/DETPOINT/NODE/detpoint_ID/unit_ID
Ishadow TDET mat_ID node_ID1
Definition
detpoint_ID Detonator identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
Ishadow Shadow flag.
= -1 (Default)
The obstacles are not considered to compute the detonation time arrival.
= 1
The obstacles are considered to compute the detonation time arrival using the Fast Marching Method.
(Integer)
TDET Detonation time.
Default = 0.0 (Real)
[ s ]
mat_ID Explosive material number concerned by detonation time.
= 0 (Default)
All /MAT/LAW5 (JWL) material law are affected by the detonation time.
(Integer)
node_ID1 Node identifier defining ignition coordinates.
  1. It is possible to define multiple detonation points.
  2. If a detonation point is not defined, JWL material law will instantaneously detonate.
  3. Detonation times are available in the Starter output file (IPRI ≥ 3).
  4. Burn fractions are available in time history file with /TH/BRIC card and BFRAC keyword.
  5. node_ID is mandatory.
