/DEFAULT/INTER/TYPE2
Block Format Keyword Defines interfaces TYPE2 default values.
| /DEFAULT/INTER/TYPE2 | |||||||||
| blank | |||||||||
| Ignore | Spotflag | Isearch | Idel2 | ||||||
Read this input, if Spotflag=25,
27 or 28:
| Istf | |||||||||
Definition
| Ignore | Flag to ignore
secondary nodes if no main segment found. inter_type2_starter_r.htm#inter_type2_starter_r__inter_type2_starter_r_fn_rt2_pn3_tz
13
(Integer) |
| Spotflag | Spotweld formulation
flag. 4
5
6
7
8
12
(Integer) |
| Isearch | Search formulation
flag for the closest main segment.
(Integer) |
| Idel2 | Node deletion flag.
9
10
15
(Integer) |
| Istf | Interface stiffness
definition flag. 16
Only used with penalty formulations (Spotflag=25, 27 or
28)
(Integer) |
