/DEFAULT/INTER/TYPE24
Block Format Keyword Defines default values for all /INTER/TYPE24.
| /DEFAULT/INTER/TYPE24 | |||||||||
| Blank | |||||||||
| Istf | Irem_i2 | Idel | |||||||
| Iedge | |||||||||
| Igap0 | Ipen0 | ||||||||
Required Fields
| Blank | |||||||||
| Inacti | |||||||||
| Blank | |||||||||
Definition
| Istf | Interface stiffness
definition flag.
(Integer) |
| Irem_i2 | Flag for deactivating
the secondary node, if the same contact pair (nodes/segment) has
been defined in interface TYPE2.
| Idel | Node and segment
deletion flag.
Note: Using Idel
results in higher CPU cost.
| Iedge | Edge definition flag.
(Integer) |
| Igap0 | Gap modification flag
for secondary shell nodes on the free edges.
(Integer) |
| Ipen0 | Initial penetration
detection flag.
(Integer) |
| Inacti | Initial penetration flag.
(Integer) |
