OS-V: 0280 Axisymmetric Elements - Interference Fit Between Two Cylinders
The model examines the contact pressure between two cylinders in case of interference fit of 20 mm.
Figure 1. Model and Loading Description
Model Files
Benchmark Model
2D axisymmetric elements (CQAXI) elements are used to model 2 cylinders.
- Material Properties
- Value
- Young's modulus
- 206 GPa
- Poisson's ratio
- 0
Nonlinear Static Analysis Results
OptiStruct | NAFEMS | Normalized Target Value | |
Contact Pressure | 2.35 | 2.27 | 1.035 |
Figure 2. Contact Pressure Between the Cylinders
Reference
NAFEMS R0081 - Benchmark tests for finite element modeling of contact, gapping and sliding
