The cross-section of the half-space in the ¼ FE model is 100x100.Figure 2. Model Details
Analytical Results:
The analytical solutions are provided by Popov, 2010. The derivation of the
analytical solution is beyond the technical scope of this document. Some key
variables of the analytical solution are as follows:
The contact area is calculated as:
Where,
Radius of the sphere.
Depth of indentation.
The applied force is calculated as:
Where,
Young's modulus.
Poisson's ratio.
The maximum contact pressure/stress is calculated as:
Results
Table 1.
Pressure/Stress
(Magnitude)
r/a
Analytical Result
OptiStruct (S2S)-Contact
Pressure
8482
8525
0
8350
8300
0.2
7700
7675
0.4
6800
6990
0.6
5100
5200
0.8
0
1345
1
Figure 3. Analytical Results versus OptiStruct
Results
The results from FEA are in good agreement with the analytical solution.Figure 4. Contact Traction/Normal (Pressure) Figure 5. Stresses 2D and 3D - Z Stress Figure 6. SPC Forces
