2026
This manual presents solved verification models including NAFEMS problems.
View new features for OptiStruct 2026.
OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
Discover OptiStruct functionality with interactive tutorials.
This manual provides detailed information regarding the features, functionality, and simulation methods available in OptiStruct.
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides you with examples of the real-world applications and capabilities of OptiStruct.
This manual presents solved aerospace verification models including NAFEMS problems.
Test No. FV2 A pin-ended double cross, in-plane vibration problem. OptiStruct is used to investigate the coupling between flexural and extensional behavior, as well as the repeated and closed eigenvalues of the double cross in Normal Modes Analysis.
Test No. FV4 This problem tests the behavior of coupling between torsional and flexural, off-center inertial axis, and close eigenvalues. OptiStruct is used in this normal modes analysis.
Test No. FV5 OptiStruct tests the repeated eigenvalues, shear deformation, and rotary inertia. The possibility of missing extensional modes is also investigated.
Test No. FV12 A thin square plate model that contains three rigid body modes. OptiStruct investigates the repeated eigenvalues and kinematically incomplete suppressions of the thin plate in Normal Modes Analysis.
Test No. FV15 The behavior of distorted thin elements in normal modes analysis is examined using OptiStruct.
Test No. FV16 A cantilevered thin square plate of 10 m × 10 m dimension. OptiStruct is used to investigate the frequencies at different modes for different test cases.
Test No. FV22 The behavior of distorted, thick elements in normal modes analysis is examined using OptiStruct.
Test No. FV32 A tapered membrane problem with irregular mesh. The geometry and mesh symmetry are maintained along the x-direction. The shear behavior of membrane elements in Normal Modes Analysis is examined using OptiStruct.
Test No. FV41 A free cylinder with axisymmetric vibration. OptiStruct is used to investigate the rigid body mode, close eigenvalues, and the coupling between axial, radial and circumferential behavior.
Test No. FV52 A well-established solid square plate, which contains three rigid modes with the given boundary condition. The test examines the performance of OptiStruct Normal Modes Analysis on 3D solid elements.
A vertical clamped free cylindrical shell with a rigid bottom is chosen to demonstrate the applicability of the structures which are partially filled such as liquid storage tanks.
Test No. 13OptiStruct is used to investigate the repeated eigenvalues.
Test 21OptiStruct is used to investigate the repeated eigenvalues and the effect of ‘secondary’ restraints.
This section provides quick responses to typical and frequently asked questions regarding OptiStruct.
