OS-V: 0420 Free Thin Square Plate
Test No. FV12 A thin square plate model that contains three rigid body modes. OptiStruct investigates the repeated eigenvalues and kinematically incomplete suppressions of the thin plate in Normal Modes Analysis.
Figure 1. FE Model with Boundary Conditions and Loadcases
Model Files
Benchmark Model
The 4-node quad elements with 8x8 mesh configuration are used to model the plate. The x-translation, y-translation displacements and z-rotational displacements are fixed for all nodes.
- Property
- Value
- E
- 200 x 109 N/m2
- 0.3
- 8000 kg/m3
Modal Analysis Results
f*
- Closed form solution
S# | Mode # | OptiStruct Results | F* (Hz) | Normalized Value |
1 | Mode 4 | 1.619 | 1.622 | 0.9981 |
2 | Mode 5 | 2.394 | 2.360 | 1.0144 |
3 | Mode 6 | 2.9896 | 2.922 | 1.0231 |
4 | Mode 7 and 8 | 4.2315 | 4.233 | 0.9996 |
5 | Mode 9 | 7.8002 | 7.416 | 1.0518 |
6 | Mode 10 (HOE) | 7.8848 | 7.392 | 1.0667 |
Mode 4 | Mode 5 | Mode 6 | |||
f* CQUAD4 |
1.622 Hz 0.9964 |
f* CQUAD4 |
2.360 Hz 1.0145 |
f* CQUAD4 |
2.922 Hz 1.0231 |
Modes 7 and 8 | Mode 9 | Mode 10 | |||
f* CQUAD4 |
4.233 Hz 0.9978 |
f* CQUAD4 |
7.416 Hz 1.0496 |
F[HOE] CQUAD4 |
7.392 Hz 1.1746 |
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
